Doug Lester
A belt grinder for almost free? Not very likely. You can use things like files to shape a blade and sand paper to finish the steel. You can make a forge body with two ceramic insulation bricks or a linear foot of ceramic insulation fiber and a five pound bag of refractory cement and a propane torch. Go to www.elliscustomknifeworks.com and take a look a the refractory supplies there. You can also build a charcoal forge in a bucket with a lining made of kitty litter and horticultural pearlite. A large canning pot filled with vegetable oil can sever as a quenching tank and quenchant. With simple steels you can even use water or brine if you feel bold. You will want to keep the blades a little on the small side if you use something like a tin can or bucket forge. You could ask you Mom to perdy-perdy please to let you use her oven to temper in or you could look for a second hand toaster over or just temper with a gas torch.
Doug Lester
Doug Lester
