Surthriver
Member
I've been using old, used circular saw blades to make my knives because it helps me to get the mechanical skill and experience without having to buy and possibly screw up good steel.
I know a lot of saw blades were made out of L6. I have no idea if mine are or not.
Anyway, my question is: Should I heat treat knives I make from these saw blades? It would seem to me that blades with carbide teeth would not be as good a steel and would not be heat treated because its relying on the carbide to do the cutting but blades that have their teeth cut right into the metal should be better??? Would they already be hard enough as long as I don't take out the temper by overheating on the grinder?
