SHOKR
hey all
i'm designing the table to carry the belt grinder (and possible disc sander). the table should carry the grinder, the motor and an inverter plus have bit of space as well.
i thought of 75x90x75cm (29.5x35.4x29.5inch) table (i'll grind sitting on a bar stool).
can you guys give me pointers, suggestions, pitfalls to avoid, so on? the height of work level will be about 93cm (table + grinder) is the set up in the first pic ok or motor too close to grinder?
these two set ups are the most simple, i am leaning toward having the motor below the grinder, but seems too much hassle.
many thanks
many thanks
