Hey, folks! Building my first 2x72 grinder here. (The NWGS). I need to do it on the cheap.
I'm planning to just do the belt-and-3-step-pulley setup as in the plans.
I found these two motors, in my price range:
http://www.automationdirect.com/adc...-Phase_Motors,_56C_(0.33_-_2HP)/MTR-1P5-1AB36
and
http://www.automationdirect.com/adc...Phase_Motors,_56C_(0.33_-_2HP)/MTR2-1P5-1AB36
They are slightly different dimensionally. The only other significant spec difference I see is that one is what they are calling "NEMA Design L" and the other is "NEMA Design N". From my own research, including the minimal info they sent me after asking them what the difference was, these specs appear to be wrong. "NEMA Design" letters only go A thru E.
There are some NEMA "locked-rotor kVA/HP" code letters that run A thru V. I suspect that's what these specs are showing, not the "NEMA Design" code letter.
Best I can determine, the "N" model would likely draw more peak current on startup, just momentarily of course, than the "L" model, but possibly up to 20% more. From what I can tell. Customer/Tech support has not provided me with any good reason to pick one over the other.
At any rate, does anyone have knowledge or good opinion on whether this spec is significant or not?
I'm just going to be running it in my garage on standard 110-volt house current circuit. I think it's a 20-amp breaker.
I guess the bottom line is, is either of these motors more likely to trip my breaker when I switch it on, or run less efficiently, or burn out sooner?
(I DO have a 220 outlet in the garage, but I'm already running my air compressor on it. I guess I could run 2 machines off it if I had to... I just don't know if that would be the better way to go or not.)
I will gladly accept redirection to any other threads that you might know of that already discuss this type of info in some depth.
And, do you think this is a "good deal"? Any better suggestions would be appreciated.
Thanks!
and
Thanks!
