Just got through reading glue wars again and reading Jim's recent response that he uses Gorilla Super Glue exclusively. If you (Jim Adams or anyone that uses super glues for handle attachment) could kind of describe how you work with it. You don't have to go into great detail about your process, but a couple of questions. I use it to "tack" things together when drilling and so on, and it seems to hold quite well (but sometimes it doesn't). I have read that it isn't great with impacts, but I like the time frame piece of it. Here are some questions regarding it:
-The biggest question is how do you work with something that sets so fast? One slip up and then what? I use slow set epoxy now and don't know if I could handle a 5 min.
-Do you attach one scale, drill, attach the other and then pin?
-Do you clamp at all? I use clamps with moderate pressure to make sure there are no seams. It doesn't seem like there would be time to get one in place before it has set up for the most part.
-Do you cover the whole tang or handle with a coat of super glue and then press together or do you put the glue around the tang/handle seam while holding it together? It seems like when I use it to tack (for hole drilling) a scale to a tang I usually mess up when I put a drop on the tang and then try and put the scale in place. It seems to set before I get it in the correct position. I do better when I hold the scale in place and then put a drop along the seam.
Hopefully this makes sense. It sounds like a bunch of ramble mamble to me!
