...All Hail King Kevin......Thanks for the facts : )
Really?
Really? :3: I have my doubts that a hopeless geek, who’s lack of a real life affords more time than is probably healthy for staring at steel cross sections under a microscope, rises to the level of such praise.:31: But the facts of what we do should always be welcomed with such enthusiasm, regardless of the provider.
All that being said, here is my take on forging. After spending quite a few years of my life trying to dispel the myths and clear up the misunderstandings about forging, I wouldn’t make a blade any other way.
First and foremost, it is the most honored way all blades were made for over 3,000 years. That has to count for something, and certainly qualifies it as a tradition worth fostering and preserving.
Secondly, it is just the coolest and most fun way one could imagine to shape a blade! I could never keep the attention of an audience of laypeople while I stood with a bar of steel at a grinder turning all metal that didn’t look like a knife into dust. But the engaging dynamics of forging, the fire and sparks, the ringing of the anvil, and the primal action of smiting something to shape, will capture the undivided attention of something very basic in anybody from 9 to 90 years of age.
Thirdly, you can’t make damascus on a grinder!
Fourthly, while very little permanent effects for something shaped as simply as a knife can be achieved merely through deformation, there are real effects on the steel if we just forget about the hammering. Forging involves multiple cycles of heating and cooling, something that can indeed have profound effects on the steel. Granted, there are about a hundred things that can go wrong in these cycles, and perhaps one or two that can be of benefit, but this puts much greater emphasis on the knowledge and skills of the smith. A totally unskilled grinder can make a knife without changing many properties in the steel itself, but an unprepared smith can outright ruin a piece of steel on almost every level. But if a smith avails himself with knowledge of what really happens inside that steel, each and every heat can be an opportunity to do some pretty cool things.
For example, a smith and a stock remover are each given identical bars, cut for the same length of steel as received from the mill. The stock removal guy will have to follow a different heat treatment, especially in soak times, than the smith; he will benefit most from a good oven. The smith, on the other hand, will be able to more effectively use a forge to heat treat because that steel had been worked from that forge. This is not as Voodoo like as it first appears. The bar was sent from the mill heavily spheroidized since most industrial applications will require easy machinability; this condition will require a long steady soak to put that carbon back into solution. Forging that steel will erase that spheroidal condition over the countless heating cycles and replace it with a fine pearlitic condition, especially after proper normalization, so the forged blade will enter the hardening heat with an entirely different structure requiring very different soak considerations.
The trouble starts when we start viewing one as superior to the other merely because they are different. Just because we create new circumstances with the forge that must then be dealt with in a different way does not mean we have made a great “improvement”, and when we consider all the things that can go wrong, we should probably be happy to just break even. Worse yet would be attempts to test our assumptions by mixing the two methods and skewing the results in a very poor apples and oranges way. A spheroidized blade, heat treated in a forge, with no precise soak will most likely provide disappointing results. It is like settling an argument over which is the greatest athlete in his field, Tiger Woods, or Babe Ruth, and then forcing them both to play baseball to find the answer. The Baseball fans could strut and gloat but in the end would only deny themselves of a richer reality.
I will finish with a statement that in past has ruffled the feathers of collectors who really like forged blades, which is ironic considering I am a lifelong, devoted, bladesmith. If I were a collector with no knowledge of metallurgy or the processes used by the maker, other than the popular marketing, I believe my chances of getting higher quality blade would rest with the stock removers. Too often the quest for the superior forged blade leaves us oblivious to all the things that can go wrong that a stock removed blade is never subjected to. Beware the knifemaker that finds it easier to redefine what a knife is than to take on the challenge of actually making a better knife; Something that neither stock removers nor bladesmiths are immune to.
