Forge help
opaul
Not sure I’m going to keep this forge but if I do I would want to have the option of running one burner or two. For those that have built a forge what components would I need. I was thinking it would make a good spare forge and I got it at a steal.
Should just have to unscrew your nozzle from the 90 degree elbow, and add a short length of threaded pipe to a gas-rated ball valve, then another short section of threaded pipe to a threaded coupler to connect the pipe to your nozzle. You can do that to both legs, or just one since you’ll always run one burner. Doing both will allow you to choose which one to run single, though. Pretty simple & easy, hope that makes sense.
You may also be able to find a single 3-way valve to replace the tee fitting and avoid the extra pipe & fittings, but I’m not sure if one is made that allows both flow paths to be open simultaneously. Maybe something like this:
Not sure if that’s correct for your setup, but just an idea for reference.
ETA: If you get the correct male threaded valve(s), you can omit the additional pipe sections entirely.
You need more garbage in your shop! That’s way way too clean lol. I’ve built a few forges, the ones I built all had electric blowers. I’ve got a Venturi forge, but I’m in the works of building a new 48” long one, with a ribbon burner that is in three sections so I can just run what I need. If you are going to run that one, I would just unscrew the gas feed from the top, add in a valve for each burner. I’ve heard that ribbon burners are really efficient, so that’s why I’m going that route. If you do much welding you may want to consider adding a blower. I added a thermocouple and DRO, the Venturi runs at 2350 wide open, might want more heat than that.
This is/will be a spare. My main forge is a Chili tobacco.
This will do it just add 2 hand valves so you can turn off the desired burner. Please note that you may have burner inconsistencies. 1 properly sized burner will always be better than 2 individual burners. Another thing to consider is you still have to heat up the entire mass of the forge so using 1 burner will take longer to heat to operating temp
Thanks 07! That looks perfect. Majestic sells the same forge with this option as an ‘upgrade’ and calls it a knife forge. Like I said I picked this up cheap and I think it was only used one time. Having a two burner option for a spare forge is a plus for me and those components you listed aren’t that much $.
More ideas for your consideration. The valving is standard except for the yellow ball valve that, when closed, directs the inlet gas to a needle valve that can more accurately control the gas flow. While each burner is controlled with a ball valve, the down side to this plumbing arrangement is that when the yellow bypass valve is closed the needle valve controls both burners. That works OK unless there needs to be unbalanced flow to the burners. I've found this arrangement works OK, but trying to heat treat to a close target temperature can be challenging.
That looks really completely.
I would keep it. If you decide you want to make longer blades it will come in handy because you can place it front to back with your current forge. That is what I do when I make blades longer than my kiln will accomodate. I have the Majestic 2 burner Artisan's forge and have used it a lot.
Got a good point there. I got it for $80 so yeah, I think I’ll do that.
I may or may not have even had my son standing at the other end of the forge with a oxy/aceytlene torch heating the tip when I made my last sword. Try to get even heat through two forges and a torch...
