You folks are about to learn just how "fugal" I try to be!
I used the Pyro-Ceram initially. I found it to work well, but I thought it was a little pricey and looked for alternatives. The ceramic is good, but I personally think that tempered glass is better. The ceramic does groove up after a while, especially if you do a lot of flat grinding on the platen. I also think the ceramic builds up heat more so than the tempered glass.
Once when I was teaching a class at Lyle Bronkhorst's place in Seattle, he was going to trash an old display case, that had 1/4" tempered glass shelves. I heard all the stories and such about not being able to "cut" tempered glass, but what did I have to loose? I tried, and it worked. I stayed after class one evening and turned 3, 1/4" tempered glass shelves into 2" strips. (I got 26 pieces of 2" X 12")...all for free. Between giving some away and using others, I'm down to about 6 left.
My Mom is big into stained glass, so I have access to a glass grinder any time I want to use it...which is how I radius the lead in/lead out edges....and have even dressed the edges of the glass to suit my needs.
Concerning thickness, my opinion is that anything less than 1/4" glass is too fragile for the application....I tried 1/8" glass once, and it cracked when I was pony clamping it to the platen when gluing it on. The thing to keep in mind is that you should use the thickness that allows you to adjust the platen face in/out, so that the platen face is sticking out SLIGHTLY further than the faces of the contact wheels with a belt in place...thats the big reason for rounding the lead in/trail out edges/ends of the glass.
David: In my experience the glass will somewhat solve the belt wear issue, simply because there is less heat buildup on the belt. When I was using a steel platen face, there were several instances where it got hot enough to literally melt the glue on the belt joint.....that made for exiting adventures!
The glass on a platen face is just like anything else we do...we have to learn how to work with it, from applying the glass to the platen face, to learning the ins and outs of using it for grinding.
