scott.livesey
Dealer - Purveyor
OK...this really shows how not to do this mod. I did this when I was first starting on this stuff and really had no idea what I was doing. I'll explain a bit further. What I did was very simple. I took a piece of steel and screwed directly into the current platen. It's about 1/8"-3/16 I believe. Then I cut off ground down the screw heads and that was it.
OK...the biggest error on my part is not getting it square and not all the way to the edges. You want to take the piece of steel, or ceramic glass, all the way to the edge and have it as square as possible.
After posting earlier that I'd post pics, I feel embarrassed at what I have, but that's what I've got. The biggest drawback with not having it go to the edge on both sides (evenly) is the two sides of your grind won't match unless you adjust for it. So be sure and get it square and to the edge and this will help until you can get something better.
hi, i have a craftsman 4x36 and did something similar. i used a 4" square "top" ceramic tile that i epoxied to the existing platen. by "top" tile i mean one edge is rounded, the others are square, the rounded edge is up. the tile was sold as 4" but is actually about 4 1/4". I have it centered right/left and can adjust the belt so i runs over each edge.
