I have read on other threads about the need to get the correct size bits for certain holes, such as the 1/8" pin won't fit in an 1/8" hole. After reading this, I realized this might be my trouble with my 1/4" pins and holes, so I ordered a letter F bit (.2570) to see if it helped.
I found out that it drills a hole that allows the 1/4 stock to pass through much easier. Before, I was having to drill and then use a file to open up the holes a little. This was a pain, but sometimes I made the mistake of "flaring" the holes in the handle material, which would show after epoxying.
My question is how loose should a pin be in the hole? Before, it was snug. Now it passes through very easily. Is this o.k.? I guess one could say that it allows for some epoxy to bind the pin in the hole.
