Hi,
After reading lots of threads, I just heat treated for the first time, and this is what I did.
1. Using a home-made propane furnace I heated up the knife until it was no longer magnetic -- tested it on a 100lb magnet. Then I put it back in the fire for a minute to bring the temp back up. The knife didn't look red, just a little pink, but it was pretty bright out, so I am assuming I just couldn't see it.
2. I quenched in peanut oil that was warmed up to about 130 degrees. No flare up, just a little bubbling. I moved it around a little, and let it cool off some more.
3. Took it out of the oil, wiped off some of the scale. Then tried running a file over the spine to check for hardness -- it didn't feel much different than another piece of scrap 1080.
The whole thing was pretty easy, straight forward, and uneventful -- and I feel like I must have done something wrong?
How does it sound to you?
BTW - it is now tempering in the oven at 450 for 2 hours x2.
Thanks!
Thanks!
