willows
Compared to previous versions of Condor I slightly changed the line.
- Blade of stainless steel N690Co, polished
- Pivot (hardened steel and made by me on the lathe) with anti-rotation system (designed and made by me)
- Spacers, Pins and pin to open the blade all stainless steel, made by me at the wheel. Stainless steel screws
- Stop Pins hardened steel
- Lock blade Linerlock (with bead lock)
- Handle: African black buffalo
- Liners: hardened steel, 1.5 mm
- Teflon Washers
When Open Length 8.8 in - 20.5 cm
3.74 in blade length - 9.5 cm
closed length 4.73 - 12 cm
blade thickness 3 mm
weight 4.23 oz - 120 g
I hope you like
A greeting to all the forum
- Teflon Washers
I hope you like
