LiamLynch
I fixed the spine, guards and choils and made up some patterns. I like the tantos so I made patterns with both kinds of tip. I also made a small version with a 4" blade but it didn't look right as a tanto. You guys were right though, as well as looking better, the regular blades feel a lot more versatile in that holding the card patterns and pretending to cut stuff felt a lot better with them. The SAK is for scale.
http://imageshack.us/a/img202/7100/photoapr07202502.jpg
The drawing of sheaths is substantially more challenging than the drawing of knives but this is what I managed. I designed the sheath for the biggest one as I want a knife to use as a camp knife and this one will do.
http://imageshack.us/a/img41/362/photoapr07224349.jpg
The one on the left shows the welts, the arcs are to show the holes are of equal distance from each other for moving the belt loops to different positions. The right hand picture shows that the kydex will be formed around the bolster for retention.
http://imageshack.us/a/img202/7451/photoapr07224403.jpg
This is a sketch of the sheath and knife. I decided 304SS was a better idea because I hate working with aluminium as it is too soft. The sheath will be held together with Chicago screws so as to be able to tighten and loosen them as the kydex expands and contracts slightly in the heat and also they can be removed to rearrange the belt loops or to mount them on the other side.
http://imageshack.us/a/img850/2265/photoapr07224406.jpg
This shows how the belt loops are attached.
http://imageshack.us/a/img255/8017/photoapr07224438.jpg
For scale, this is 5mm square paper so the sheath is 8mm thick and 10mm with the belt loops. I want to use 4mm steel for this knife so I will have a 4mm welt, the kydex will be 2mm.
http://imageshack.us/a/img706/2323/photoapr07224434.jpg
This is something I am designing so that I can wear the knife at a more comfortable height. I figured it might as well go here. It will be made from two bits of 40mm polypropylene webbing and allows the sheath to be worn at thigh height. It is more convenient for when I use the knife as I won't have to lift jackets and what not. It has a pouch for a sharpening stone because when I make this I want to be able to put it in my BOB and not worry about it getting blunt. If I am carrying a knife I will probably have some use for a flashlight and I want it to be as accessible as the knife so it stands to reason that they should be in the same place. It takes an extra inch of webbing to make a flashlight holder so there you go. I have put button holes on the webbing belt loop as I never wear a belt. Since you can't wear a knife on braces (suspenders for you Americans) I will sew buttons on to my trousers to mount the knife.
(I know it took more than a minute.)
