Hello all, I've got a question about buffing compound. I've noticed buffing compound tends to develop a dark color, even on while or red rouge as I'm buffing. Is the compound turning dark because I'm pressing too hard at too high RPM causing the compound to burn turning dark?
I'm using a 1hp, 3450 rpm motor on an 8" muslin wheel, both loose and sewn wheels.
Should I be using less pressure to keep temperature down to prevent the rouge from turning dark? OR - using a 1725 RPM motor?
Thanks for any suggestions 'n guidance,
Ken H>
Ken H>
