willows
Hello guys, I present my latest creation.
The line is a classic, slightly revised by me in some points.
The guard (which usually in this knife is formed from a single piece U) is made by milling two semi-U joined by means of two rivets. The guard is NOT sealed, the pairings were made with numerous manual adjustments.
Stainless steel blade MA5M. Tapered shank. Blade, tang and guard highly polished. Guard stainless steel 416. Handle: Buffalo Horn of Africa. Pins style Loveless (octene / steel) made by me on the lathe. Genuine leather sheath.
total length 8.27" - 21 cm
blade length (cutting edge) 3.55" - 9 cm
thickness 4 mm
weight 0.33 lb - 150 gr
I hope you like it
Greetings to all!
thickness 4 mm
I hope you like it
Greetings to all!
