sunny_2_75
Member
Hello everyone, I'm currently thinking about getting/ making a 20 ton pin press for pressing the pin stock on my bolsters. Here's how I've been doing it. I've had mixed results. Currently I prep the bolsters as most do. I glue (epoxy) the bolsters in place...holes for pins pre drilled. I set pins in place and clamp bolster till glue dries. Immediately after clamps have been set...I remove the pins. Once glue dries , I clean the pin holes with proper size drill bit. I then mushroom one side of the pins and place in pin holes. Cut excess pin length on non mushroomed side. I then begin to peen the pin stock. I don't seem to consistently get a good weld of the pins and at times get a small black ring around the pins after I have tapered the bolter and handle on the grinder. I believe the weld is good at the top of the bolster but not all the way down through the bolster. Would a hydrolic press do a better job of that?)
