So, I'm looking for a bevel-style "bit" to fit into my drill press which will grind a good bevel (ideally, 60 degrees from vertical) in my bolsters (untempered 416 stainless); I presume I'll need a diamond-impregnated type but cannot find any such animal on-line. With the number of tools for any occasion out there, I cannot believe that something like this is so hard to find. Straight edges and outside curves are no problem, but inside curves are a bugger.
In a perfect world, 1 to 1 1/2 inch diameter at top of cutting face (1/4 inch shaft) and 60 degree angle, measured from vertical (looks like a point down cone), although I can be flexible here.
I've tried every stone style bit out there, and they ALL end up being ground down by the stainless. Useless. Anybody have any suggestions or manufacturers out there who can direct me accordingly?
