Two bird & trout knives recently done. One in Dichrolam, and the other in green rag micarta
LSKnifeCo
New Member
Both look very nice. How robust is the dichrolam and how easy is it to work with.
Doug
Dichrolam is a backing of .060 Dichrolam over acrylic. As long as you don’t grind down into the laminar layer, you’re good. I’d say it’s similar in workability as kirinite or other a acrylic based scales. From a durability perspective, drops would likely result in marring, but as long as it didn’t crack the acrylic, it should sand and buff back out fine. I take it up to a 3000 grit and then buff with a pink scratch less compound very lightly as to not melt it. In working with other similar materials, the heat produced with heavy handed buffing can leave smears and streaks.
