the tuna sword
LR Harner
so W2 steel from aldo a bit of clay and a quench in water then in parks 50 (to keep the blade from taking much arc)
gane "guard" of brass nic-silver and copper. nic-silver spacers and screw o cap
black wood is the smaller and buckeye burl is the main of the handle
the blade is 24 inches or so and over all it is 38
this is a single bevel blade used to brake down large tuna but i dressed it up a bit
the front of the grind is much like a sword but he back is hollow ground on a wheel in the 3-4 foot range (mine is a 4 footer platten)
this makes for a blade that is able to be nearly layed flat on the hones to be sharpened but also has an angle set at right around 15 degrees
Dan Pierson
WOW! That's one impressive piece Butch. Given the fine edge I assume that it's
actually used rather delicately?
LR Harner
i l get more pics and video posted as i go and i think this blade warrents getting a pro to shoot
[video]https://www.facebook.com/video/video.php?v=1988537672542&oid=121228181225150&comments#[/video]
LR Harner
oo and yes the edge is built got slicing and not say mat cutting demos tho i do think that i might try my hand at making a demo cutter at some point
