Chris Railey
I have a three phase 2 HP. motor running through a KBAC 27D controller on 110 volt. I am going to change it to 220 volt running through the same 27D. I know I need to re-wire my motor to run on 220 (the diagram is on the side of the motor) and I need to switch my Jumper wire on the 27D from 110 volt to 220 volt. I also will need to replace the 110 plug with a 220 plug. Is there anything special about the 220 plugs the 27D uses or will one form Lowe's work like on an oven? Also, am I missing anything?
