Starting An Elk Antler and Sanbar Stag Antler Knife
DanF
I ran across a very well shaped piece of elk antler so I thought I would also use up a piece of sanbar I have while I am stinking up the shop.
Using thin cyanoacrylate glue to penetrate, this stuff is like water and is great for turning projects and the cracks that develop while turning.
You can see where the drops hit and spread. Once I saturate with the thin, after drying, I follow up with regular cyanoacrylate until I feel the pith is filled and stable. Gluing is a slow process as the stuff get very hot so I wait until it sets and cools before applying more.
I usually use a cleavis pin/hinge for hidden through tangs, but with this full tang I am borrowing an idea from akwildman's recent thread on his knife build (thank you for that technique!), so I can use a pommel.
Screw fitted for mounting later, it will "float" so it will fit flat and flush in place.
All components rough fitted.
The other blade will be a just a bit bigger.
More to come another day.
Edit 2nd and 3rd pic reversed.
DanF
Slow going right now, working on too many at once.
I haven' done a swedge in a long while, thought it might be fun. Not.
More work on it and plunge lines needed.
DanF
Blade finished except sharpening, hand sanded to 600, then backed down to 400 and wrapped for protection.
I found this respirator to be great for full beards, called the resp o rator.
I'm going to break the pics down as I am sure to mix things up as I go along. More coming.
DanF
The antler scales as they presently are, are too big in diameter for this knife, and too round and need to be sanded. Antler and bone do not like heat so I will take it slow, alternating each side to allow plenty of time for cooling.
They extend beyond the spacer so I will sand them to flush, and slightly tapered front to back. There is also a slight gap where the right scale is not truly squared up where it meets the spacer.
Scales thinned to flush with the edge of the spacer and most of the gap has been taken out, but needs a bit more sanding.
Next I will be shaping the finger guard prior to permanent installation. Thinking about using a pin press like I saw on usaknifemaker.
Von Gruff
Taking a quick look at fit.View attachment 68752
I have been looking at a better respirator than the half mask I have which never really seals against my beard. I have read positive reports on them but it was the blocking the nose and only breathing through the mouth that had me wondering how comfortable they are for a coupe of hours use at a time.
DanF
It took me a couple days to get used to it as I have never snorkled or scuba dived. Now I don't even use the nose clip as it has become second nature for me. For the first 3 or 4 days I experienced a bit of dry mouth/throat from mouth breathing. Haven't noticed that since the beginning. From what I have read/heard, there are better types out there , but cost hundreds of dollars.
Some days I forget I have it on.
Von Gruff
I have just ordered one Dan. Thanks for the feedback that mirrors what others have been saying
Smallshop
Anthony Self did a vid on using a C-Pap machine...positive flow and goes over the nose and doesn't fight the beard...of which his is spectacular...lol. He puts it in a drawer under the grinder where the dust can't get to it...
Dan...great WIP!!
DanF
Putting this one on hold for a few days, rewiring the shop again (third time, more equipment each time). Didn't want to appear to be abandoning this.
Doug Lester
That's nice looking knife you have going there. I do admit that the picture of the blade hanging out over the edge of the knife board gave me the willies though. You could really cut yourself or, worse yet, stab yourself with it hanging over the edge that way.
Doug
DanF
You are correct, Doug, that would be an unsafe practice for sure! I had released one of the toggle clamps to swivel the blade around for a better picture.
