SGENSH FORGE BURNER
Jim Levite
an incredible BRAND NEW SGENSH Forge burner for sale. Made by renound maker Stephen Gensheimer. This is PROBABLY the best burner made!! Again, BRAND NEW burner with removable SS flare and in depth owners manual. $135 shipped PRIORITY MAIL. PM IF INTERESTED.
The burners tend to run a neutral to slightly reducing flame throughout the pressure range and have been used to weld billets for hours at a time. The burner is made from drawn over mandrel tubing rather than common black pipe and is accurately drilled in a milling machine fixture before the interior of both the tubing and the holes are honed. The gas injector in these burners is fixture drilled to create a long smooth gas injection orifice before the rest of the injector body is drilled turned and tapped for the gas line fitting in a turret lathe. The two parts of the burner are tig welded together in a very precise fixture and then each burner is tested for function over a wide range of pressure.
