Mark Barone
My plunge lines tend to be almost 90 degrees. I know if I hang the belt over a bit it should give it a bit of a radius. I have yet to achieve it. maybe I’m not hanging it over enough and. Any tips?
I do it all the time.... my advice for the amount of belt to hang over is..... twice as much as you think you need.
Also, if you don't already, always start a grinding pass in the middle of the blade. Lay the blade on with very light pressure in the middle, go back to the plunge, and when you reach it, THEN you apply whatever pressure and torque you need... then make a complete grinding pass.... and repeat, repeat, repeat until you done. I always stress making complete grinding passes because if you get fixated on a given area, that's usually when thing go wrong.
