SHOKR
hi-lo!
I'm preparing to do my first in house HT (quite literal in my case since my HT oven is in the kitchen!)
I want to do a stress relief before hardening, from supplier data sheet:
Stress-relieving
After rough machining the tool should be
heated through to 650°C (1200°F), holding
time 2 hours. Cool slowly to 500°C (930°F),
then freely in air.
I will probably heat following that process but let it cool in the oven
I will be using foil, do I have to change foil? or use the same one after that for the hardening process?
and is 2 hour too much for a knife? (aprox 5mm thick)
(any other tips or info for the HT process is welcome)
thanks!
Stress-relieving
then freely in air.
thanks!
