Daniel Macina
OK so last night I had the Forge going and all of the sudden without touching anything the Gauge went a lot higher than what I had the regulator set at But the actual pressure went way down. Now Gauge won’t go below 10 psi and I can open the regulator all the way in the Forge acts like it’s running at two PSI. This is a brand new regulator from high temp tools and also a relatively new propane tank only have about an hour on it and can still feel it’s mostly full do you guys have any idea what the problem might be? I am on a tractor and using voice to text to write this so hopefully it makes sense. If you need more info just let me know.
