PostImage
Dennis Morland
Does anyone else use PostImage for their hosting site? If so, what is going on with their site? I noticed all my pictures disappeared here on KD, again. Arghhhh!
Dennis Morland
Took this off their website. For a very low tech guy, I need someone smarter to explain what it means...
postimg.ORG domain is locked by Registry, no prior notice.
While we hope to resolve the issue, we chose postimg.CC as our new home.
Please update codes embedded in your websites.
Dennis Morland
Thanks for the heads up Dennis. It looks like you can go to www.postimg.cc instead of www.postimg.org to get to your photos.
I tried to update a thread of mine on here and got an error of too many images in the post. Not sure what to do to fix that.
Thank you Gene. I figured it out with your help. I had to go back into my picture thread and change each of the former picture doo-hickeys.
Gene Kimmi
Good! I tried to change the links in my thread, and it worked for a few. Evidently the old links are being counted on the 20 picture per post limit, but they don't show when I go to edit them, so I can't delete the old links.
I'm going to wait a day or two and see if post image gets their end fixed. Maybe I won't have to re-link each image.
Dennis Morland
Gene - I had that problem also. I could not get the links to show up. When you go to edit the post, along the top of the window when you open the link is a gear thingy. If you hover over it - it says "Toggle BB Code". Click it and it opens the links. Instead of deleting all the old links, I just changed the .org to read .cc and it worked out just fine.
Smallshop
I post all images related to KD right on KD....when you want to post a photo go to the "attach files" button at the lower left and pick the photo you want and it will load it and keep it here at KD....no need to ever worry about it again.
