PID ribbon burner? Anyone here done it?
BossDog
Staff member
Has anyone here put together a PID controlled ribbon burner forge?
Wayne Coe
Forum Owner - Moderator
I use a pid with my Ribbon Burner forge. The temp in not controlled by the PID but the forge does do well at maintaining an even heat. Fred Rowe has a PID controlled forge, last time I was there he didn't have a Ribbon Burner forge though.
Check out the Build a Gas Forge and the Ribbon Burner attachments on the Forge Supplies page at www.WayneCoeArtistBlacksmith.com. Let me know if I can help you.
Gilbert M
Member
I would be happy to help if I could I've made a couple using information from my mentor Tim Hancock, Wayne Coe and Eric Fleming. Here's a shot of my two, as they say a picture is worth a 1000 words.
BossDog
Staff member
That is a nice set up and looks like where I want to head.
I need to start pulling together my parts.
Gilbert M
Member
I think you'll be very happy I can get mine down to about 1150 degrees running pretty smoothly and no problem getting up to welding temps either.
Gilbert M
Member
There's a constant flow controlled by the lower needle valve I try to keep that one just below my target temp. The second needle valve controls the solenoid, that one is on fairly low dependingon what I'm doing.
tkroenlein
Thanks. That seems like a pretty darned good set up.
