OPauls Knife Picture Thread
opaul
Opaul - You got your shop set up and organized and now you are just hammering them out. Keep up the great work.
Thanks Dennis. Being retired certainly helps.
I will say the TX90 is a great grinder. I’ve started grinding a little differently. Travis (TX90) suggests using the wheel and tool rest to do the initial grind - hollow grind. Then switching to the flat pattern to complete a full flat grind. I’ve done a few blades this way and like it. I’ve done several larger blades that way. Small blades aren’t worth the tooling arm change outs. But I can see where it saves wear in the platten and sanding belts.
