no belt grinder how to convex?
Discussion in 'Knife Maker Shop Talk' started by graveyard, Jul 7, 2013.
  1. graveyard
    graveyard Well-Known Member
    i use a side grinder & files so on how can i convex a grind by hand?
  2. rhinoknives
    rhinoknives Well-Known Member
    You can file the top third of the knife at 10-20 degrees depending on how tall of a blade, and then the bottom third of the knife at a corresponding degree then round the middle with a file to match.
    For finishing, I used corrugated cardboard with sandpaper and rolled the knife. It a lot of hand work but you can achieve a smooth symmetrical grind and finish with patience and a large can of elbow grease.
    I hope this helps, I am sure there are other ways to do this without a grinder?
    Laurence
    www.rhinoknives.com
  3. LiamLynch
    LiamLynch Well-Known Member
    I filed the edge like I would to get a flat grind by draw filing. I used a sanding block to finish the flats to 120 then a soft sanding block to sand the rest of the blade, I started from the flat and progressed to the beveled area and it made it curved. I got quite a nice Appleseed grind.
  4. rhinoknives
    Liam's method sound easier than what I did years ago. The cross section of a apple seed is what we are after here.
    Laurence
    www.rhinoknives.com
  5. LiamLynch
    You don't even have to try, it happened by accident when I did it but I wasn't complaining. You can use the handle of the file to keep the angle roughly the same. Part of the reason it goes convex is the irregularity in filing though. I guess if you used precision equipment it would be slightly flat in areas but you can barely notice, it feels like a smooth curve.
  6. Geoffrey
    Geoffrey Active Member
    I use an automotive sanding disc, I have used this on axes and on knives. I convexed an RTAK for a friend with nothing more than a drill and the automotive sanding disc attachment.
    [video=youtube;fgsy2SusaO4]https://www.youtube.com/watch?v=fgsy2SusaO4[/video]
Share This Page
