New: Morakniv Garberg Multi-Mount Utility Fixed Blade Knife
Perryknifeworks
The blade of the Morakniv Garberg Multi-Mount knife is .13" thick and made of high quality stainless steel, placed on one of the sturdiest models they’ve ever manufactured. The Scandi-grind grinding makes the knife easier to keep sharp and the spine of the blade has been ground so that it can be used with a fire starter. Only your imagination can limit your possibilities with the Multi-Mount. The range of mounting options is endless, thanks to its Velcro strips, straps, holes, and notches. And of course, it is MOLLE compatible.
  • Overall Length: 9.00"
  • Blade Length: 4.30"
  • Blade Thickness: 0.13"
  • Blade Material: 14C28N
  • Blade Style: Drop Point
  • Blade Grind: Scandi
  • Blade Finish: Satin
  • Edge Type: Plain
  • Handle Length: 4.70"
  • Handle Material: Polyamide
  • Handle Color: Black
  • Weight: 9.60 oz.
  • Knife Type: Fixed Blade
  • Sheath: Black, Multi-Mount
  • Brand: Morakniv
  • Model: Garberg
  • Model Number: 12642
  • Country of Origin: Sweden
