New full tang tomahawk model {The Valkyrie} Build Along
Benr.t
Hey guys I have recently designed and am in the process of building a new full tang tomahawk. I have been asked to to a larger model, so this is it.
I understand "tactical" tomahawks aren't some of your guy's thing, but I know a few of you like them, so I wanted to share. I have snapped some pics along the way to show some of my processes.
I had the hawks waterjet cut from a very large sheet of 4140, but they still need quite a bit of work to clean them up. Here I am cleaning the top profile on one of them.
[video=youtube;sEGwJG9Bhdg]https://www.youtube.com/watch?v=sEGwJG9Bhdg[/video]
Next I go through and drill all the holes to their final dimensions.
I made a simple little template to mark where I will hard stamp the blades. I use a 12 ton press that I built for the job.
And the results
The axes had quite a warp to them for some reason, so I straightened them out prior to grinding. Here is one on my granite surface plate, nice and flat now.
Here I am scribing the lines that I will grind to.
Benr.t
Here I have ground the first bevel.
The compound grind on the spike. I wanted a beefy point that would still penetrate very well.
All ground and ready for HT.
I have a large vertical kiln over at my Dad's place I use for my bigger hawks. Here it is coming up to temp, it takes about 2 hrs to reach 1550.
Opening a vertical kiln is WAY hotter than a horizontal, I need to upgrade my gloves.
[video=youtube;RgOU0V2BzF4]https://www.youtube.com/watch?v=RgOU0V2BzF4[/video]
After hardening, they get a full temper. I then blast them and then spring temper the tang for extra toughness. The axes warped a bit during quench, so I straighten them at the same time. This one is nice and flat again.
Next up finishing!!
Justin Presson
I have been following the progress on instagram too, it's looking good. I like the video of you quenching it....that would get my blood pumpin.
Is that a homemade edge scribe? I need to make me one.
Benr.t
Thanks Shawn!
Yes Justin, I made the scribe. I think Tracy sells one like it, if you don't want to build one.
Benr.t
I decide to do something new for this model and mill "fullers" in the scales. I built a simple jig to clamp in my vise, and started cranking. I really need a powerfeed. : )
[video=youtube;-CtCT4LKPYI]https://www.youtube.com/watch?v=-CtCT4LKPYI[/video]
The end result. I will still round and smooth them out out by hand once they are attached.
This set of scales is for a custom order. Love the look of CF, just hate the itch.
Here I am flaring the tubes for a rock solid handle.
And the end result all finished up and razor sharp!
A better pic of a different Carbon fiber one.
Benr.t
Hey guys, I have received some messages regarding the hawk asking about things liking puncturing tires and sheet metal and such. I was able to get out and do some testing with it and am very pleased with the performance.
Here are some pics. I will try and post the video later.
ter..
christopher
Hi Ben just wanted to ask why valkyrie ,They were females who chose the slain in battle in norse
so its a axe for females then ? or is there another meaning for valkyrie ?
Chris
Benr.t
Hey Chris,
Yep that is the meaning of the word Valkyrie, "Chooser of the slain". The axe has norse influences in the shape of the head, plus I just like the name. : )
rhinoknives
I got a little nervous when you said you were going to test the Hawk on car doors & Tires?
Not on my vehicles you don't!:no:
