15n20 most definitely can be heat treated like 1084, but it is optimum if you can hold at temp for 5 minutes, to help get the nickel in solution. The nickel is there to help in hardenability (deeper hardening), toughness, and some corrosion resistance. I think the corrosion resistance is a myth, to some extent. Nickel will make a steel a little "shinier" but it's corrosion resistance is nill. A knife with 15n20 will patina just like 1095 or any other carbon steel.
