Making your own pocket clips?
Justin Presson
Who is making there own pocket clips for folders?
If you are bending them out of titanium any hints or tricks? I'm about to make one.
Thanks
JP
Entropy762
How do you guys attach your pocket clips? Drill and tap the handle material or tap the liner and drill a clearance hole in the scale?
Jacob
BrandantR
I've both milled and bent pocket clips to fit my knife designs. You definitely want to use heat when bending either steel or titanium. I've seen dedicated clip brakes for bending which are really nice, but a vise, a dowel, a set of pliers, and a torch will get you there.
gudspelr
I made my own Ti clip out of some .050 sheet and you definitely want to heat it as has been mentioned. I think .040 probably would’ve been slightly better for me. If you’ve done any sheet metal work before, there are definitely some similarities. Making hard angles is harder the thicker the material-you’ll get a slight radius where the material “bunches” up. I used a cereal box and drew on it then cut it up for a bit of a template. I put that on the Ti and cut that out oversized. I drilled clearance holes in the clip and scale, then tapped the liners. I wanted the clip to sit down into the scale, so I carefully marked the scale (micarta) and milled our a recess and kept checking for the fit.
The clip is certainly functional and I’m glad I made it rather than using a pre-made one. I feel like making one to match the design of the folder helps add a nice touch. That being said, I learned a lot and hopefully the next ones will be nicer. Hope yours turns out how you want it.
Jeremy
Justin Presson
Outstanding work Justin! I haven't tried bending a Ti clip. I'm planning on milling them. I've only done a hand filed/sanded Carbon Fiber clip for a Morpho Balisong. And it came out really nice. Planning on milling the Ti to the same effect.
Yes if I had a mill I would try that to. I actually prefer a deep carry clip but I'm going to have to put my thinking cap on to figure out how to pull that off.
gudspelr
That looks great. I like deep carry as well, so I bent mine twice so the part that attached to the knife was in line with the clip...if that makes sense...? I’ll try and find some pictures to post up to help show what I mean. It’s two 90 degree turns and it can definitely get a little wonky. But I like the result in pocket.
Jeremy
gudspelr
Sorry it took a while to get these pictures posted. Here is an in progress one and with it on the knife. Hopefully it shows what I was talking about... I milled a pocket into the micarta so the Ti on the clip is sunken into the scale.
Jeremy
