Lock back whittler
Craig
3 3/4 closed lock back whittler. CPM 154 blades and springs, integral 416 liners/bolsters with jigged bone handles.
Calvin Robinson
Moderator Christian Forum
Very nice Craig. I'm baffled as to how you did this. Are the ends of the slipjoint springs extended to act as the spring for the lock bar?
Craig
Thanks Tracy and Calvin.
Yes the springs turn down at the end of the lock bar and curve up under it to keep tension on the bar. There are two pins in the center of the spring to keep it from rotating. I will get you a photo of the springs that should help more than my typing.
Craig
Calvin here is a photo of the spring.
Calvin Robinson
Craig
Craig,
Thanks for the photo,that's exactly what I imagined when I first looked at the knife.
Amazing work!
dan van
Like the Boss Dog said "wow...that took some work". It's great to see a piece of work that you invested a lot of time into and it turned out great! Dan
