Knife grinders
Aikenn
Active Member
Hey all post here looking for recommendations for a new grinder. I guess I will give some idea of my requirements. I wan one mainly for folder work. I have two semi home built vertical grinders. (need a new bigger work table), but an ideal unit horizontal with a three(3) inch wheel a one and one half inch(1-1/2) wheel and flat work area with a platen. I though of a tipping grinder but don't think I can get all my requirements. Or should I scrap the whole idea and go to two flat disk grinders????? Come on dont be shy I can take it give me your best shot..
Aikenn
Active Member
Hell if someone is NOT ood wih heir hands a person could spend 2-3000$ easy Guy at blade show w/ surface grinder attachment thru the roof what does a Burr King cost now just the basic??? What I need is a horizontal for folders.
Aikenn
Active Member
What is your budget?
Hey Tracy starting this quest for info was really a pie in the sky. Thanks but not one recommendation did I get is worth a flip. I guess I was at fault for being so general. My bad , quess I will go with plan "B". There are some great grinders out there in every form and function. What I REALLY want is a horizontal or THE HINGES TO FLIP OR LAY DOWN A VERTICAL. My budget is ALASP I am retired on social security.
Aikenn
Active Member
I did a google search on horizontal knife grinder plans and found quite a few different options. Perhaps this will you get you started.
https://www.google.com/search?client=firefox-b-1-d&q=horizontal+knife+grinder+plans
If you have two vertical grinders now, perhaps you could adopt one for horizontal use based on some of the plans mentioned in the URL
Yes but i have a third that i was thinking of doing just that. But NO ONE wants to share a well made hindge with clear dimensions.
