Issues with 80crv2
TheNuragicForge
New Member
Hi everyone! I'm from Sardinia and we have a good tradition in knifemaking. I've been making knives since I was 15, that said I've always used the same 2/3 steels I knew (mainly 1084, 1095 and 12c27)
I've recently tried 80crv2 for a couple of builds but I'm a bit confused here
Like this knife below ( stainless steel handle with buffalo inlays) has been normalised 3 times, quenched in p50 and tempered twice. I had 61/62 HRC on the scale, however my usual sharpening method doesn't seems to work as good as on the other steels I always used.
I've tried to stop at 2k grit on the stone, it give a inconsistent burr, barely visible (is not as big as 1084 for example) at the same time is tough to remove, doesn't come out easily.
I've tried wood, I've tried stropping with leather ( with and without diamonds paste)
I've tried bringing it up to 3k grit...but still I'm no satisfied with the cutting performance.
It's a 3mm blade, hollow grind, should fly through anything...but it doesn't.
Any suggestions?
Thanks
Try stopping at 400 grit and stropping. This being a bit more complex steel than what you are used to, sometimes they can be difficult to sharpen at higher grits because the burr breaks away before it can be removed to give that “razor edge”. The 10xx steel has very low carbide volume, and makes a strong, flexible burr that lasts way up into the fine grits. That should be able to get shaving sharp pretty easily, 80CRV2 is pretty good stuff. I don’t use it anymore, but I used a 400 grit water stone and strop with great results.
