opaul
I have a basic concept of how this is done but have not actually completed one. I guess there are several ways to go about it. With the proper patience and measurements I'm assuming the tang could be threaded (female) and then the handle counter drilled on the butt cap and the handle affixed to the blade by using a bolt to fit up. Another way would be to thread the tang (male) and recess the nut in the butt cap by counter boring and then using a dyed epoxy fill.
Most of what I have been doing is threading the tang and then threading the butt cap and securing the handle this way. This leaves the bolt visible in the butt cap or on some occasions I have peened a small protruding section of the bolt over. I have also thru drilled and slotted a bolt to extend from the tang to the butt cap, which gives a little more flexibility in positioning the butt cap if it does not come parallel in the fit up.
I'd really like to do recessed method or hidden method.
What methods do you guys use when doing a through tang? If you don't mind sharing.
