Dwane Oliver
So I have finally gathered and scrounged enough materials to build a nice BIG forging press.
I want a single post press, I dont know what else to call it , that you can work from 3 sides.
Looking around the web and around here , I see some nice ones , like Mr Bumps.
http://knifedogs.com/showthread.php?14340-Basket-Weave-Damascus-in-a-Canister&p=133563#post133563
I was thinking.......(too much probably ) about putting the cylinder on the bottom, instead of on top.
This would drastically reduce the weight of the overall press, by not needing all of that beam below the dies.
Ok , I have never had the pleasure of using a press.
SOoo would this work ok?
Or would it be a PITA , with your material moving up and down with the cylinder.
OR are there other reasons that nobody builds them like that?
Thanks for any input you guys have
Dwane
Dwane
