When using cable..... it's a very big "Give-n-Take" situation. The larger the individual wires in the cable....the more functional blade it will produce. The downside is that the pattern/eye appeal isn't anything to shout about.
Flip side..... cable with smaller diameter individual wires produce a striking pattern, but because the wire are small, they decarb significantly, and sometimes entirely........ and the end product is usually only mid to low 40s Rc as hardened (before any tempering). That's the best I've been able to determine....because trying to Rc test a cable billets is like herding cats.....all over the place because of all the decarb lines.
I've made a ton of cable blades in my career, and can tell you this..... if you want high quality FUNCTION, use XXX improved plow share, with the largest individual wires you can find. If you want eye appeal, then look for the same thing with smaller diameter individual wires.
The pattern in cable comes from decarb of each individual wire.... and decarb can be anywhere from .002" if your welding technique is near perfect, but expect closer to .008-.010" or more. That means that if the individual wires in the cable are .010", and you get say .005" decarb (that's from all sides of the wire).... you've basically got mild steel, or a low medium carbon steel in the end product.
Just another one of those "Give-N-Take" things we have to consider/deal with when it comes to Bladesmithing/Knifemaker!
