Thunter124
I'm out of town up here in Charlotte, North Carolina, for the week. I've brought all my reading resources, drafting gear and whatnot, for when I have nothing to do. But I got a couple of things on my mind: one is the fact that I have found an abundant source of thick oil rig cable(theoretical miles of the stuff) and I need to figure out how I can work with it, as well as what I'm going to need to work it and techniques to make my life easier trying to get it into something workable.
1. If anyone knows about the general usefulness of the oil rig cable: is it generally a metal capable of hardening and holding a reasonable edge?
2. As far as cleaning the cable is concerned, what methods can you use to remove the oil, I know there is always just burning it out, but is it possible to use a cleaning agent in a vat to soak the oil off of the cable. It would make it easier to clean large lengths of the stuff. If so does anyone know of a good chemical?
3. would it be a fast, slow or intermediate quench in general? I know I would have to do my own testing seeing as its all somewhat different, but how does it usually play out for people using cable damascus? I've read through that section in my $50 knife shop 10 times now, but multiple sources are never a bad thing.
4. As for forging it down, by hand, I bought an 8lb sledge before I left home(I need to dress the faces on it) when I started hammering on an old leaf spring and my 2-3 ish pound brazeal hammer just wouldn't move enough metal. For getting the wire welded together will it be better to use the lighter hammer in rapid blows, or the heavier sledge and heavier more deliberate blows?(either way I am going to weld up the ends before welding, as opposed to the loose wire) I will be moving to hydraulic press at some point in the future, but that is at least $600 away right now(air compressor died, so nothing to power the air/hydraulic if I had one)
5. On finishing, how will a waterstone finishing effect the look of a finish blade? Will it bring out the different colors on the different hardened areas like an etching would, one thing I have read on japanese blades, is that the stone finishing brings out the hamon because the softer portions and the harder portions are scratched differently. If it does work this way, is it a very subtle difference, or can it bring out good definition?
6. On a differential hardening, will it be able two show two defined regions or will it blend in with the different regions within the damascus itself. or is it a situation where you get shade in the damascus of(on a scale hypothetical 1-10 with one being a white and 10 black) 5 and 7 normally, but after a differential the blade portion would come out a 3 and 5, the spine 5 and 7.
When I started typing this we were in a mall looking around to pass some time, and I stopped in a radio shack on the off chance they had some etchant, lo and behold 700 miles from home, I was able to pick up 2 bottles of feric . So now I got another piece of the knife shop puzzle to look forward to on the return trip!
Any help on any questions would be appreciated, just trying to confirm/deny/expand my body of knowledge.
-Hunter
-Hunter
