Etching machine build.
Daniel Macina
As some of you know I’ve been working on building an etching machine from the Chris Crawford plans. This is been my least favorite dealed of all time and I wouldn’t ever do it again but here’s hoping it works. Got it to turn on that’s a start more to come after dinner6893568936
Sean Jones
That looks good Daniel. I built one exactly like that a few years back. When I first turned mine on I blew a couple of the inline fuses in the unit. If I recall correctly I had something reversed. With the low voltage and amps any problems should be easy to fix.
After sitting on the shelf for a couple years, I've started using mine and it works like a charm! Yours should also.
Daniel Macina
I keep blowing the fuse when switching to AC for some reason. A shower some dinner and then I’ll try and figure it out. On my last fuse
Gliden07
Nicer looking than the one I built. I went super easy. Got an old HO train transformer. Wired the the DC to one side of a DPDT center off switch and the AC to the other side. The 2 other leads to blade (positive) and other to negative or hand piece. Cranked the DC side all the way up, DONE! A tad under powered but it works good just takes a little longer.
Daniel Macina
With the fuse blowing when switching to AC wouldn’t that mean something is off with the bridge rectifier? Isn’t that what allows it to change between AC and DC? Someone also told me you have to swap the leads when you change between DC and ac is this correct?
Sean Jones
You shouldn't have to swap the leads. I'm not sure about the other part. It's been too long since I built mine to recall exactly. I think I had a couple of wires backwards. But which one's I don't remember.
Sean Jones
I thought about this some more and recall when I was having a similar problem I went back through the steps on the electro-etcher page one by one and verified that I had them hooked up correctly. Mine's a lot messier than yours but I opened mine up and here's a pic. Not sure if it will help as mine isn't color coded, etc. but might give you an idea.
68938
Bill Vining
Dealer - Purveyor
I used one of these for years until I tried to use it as a carbidizer. A little smoke and a few crackles later, it ended up in the trash. As far as an etcher goes, it always worked great.
Heikki
I also built the same one. It should work great for you.
I'd like to build a better marker for mine, maybe out of graphite? Those of you that built your own, what kind of marker did you end up with?
Sean Jones
I could use a better one also. Mine is super simple. I took a small piece of wood drilled a hole in it ran a piece of 14 gauge wire thru it and soldered that to a brass plate. I have a bunch of felt and just wrap a piece of felt around the whole thing, wet it with solution and I'm ready to go.
Gliden07
That's what I need to do too.
I took a 3/8" pcs of brass got a brass 1/4-20 screw of appropriate length had an old broken plastic gardening shovel with a plastic handle drilled through the handle and tapped the plate. Screwed the whole mess together.
Daniel Macina
Well turns out I had the switch wired wrong. It’s running now. Still something wrong with the AC side of it though because it’s not darkening at all. I’m also going to dial it back to 12 amps because I can already tell it’s going to burn through the stencils pretty quick the way it is. 68961
Daniel Macina
Wow very professional looking, both machine and mark. Did you buy the plans or does he offer them on a site?
Thank you sir! Check out Chris Crawford‘s plans. They are actually Bob Warner‘s plans I believe but cleaned up and made easier to understand. I changed this one to 12 V instead of 24 because 24 was going to burn my stencils. Also some of my parts were numbered different so it was a bit of a challenge but Chris Crawford’s site will give you a good starting point. That being said though I didn’t really save any money so you might be better off just buying one.
