embedding Youtube vids?
Les Voorhies
Badge Boss Admin Dog Catcher
It might not be allowed in the settings but I know it can be allowed. If Tracy gives the ok we can look into turning it on, I'll look and see if I can tell where the settings are.
rfrink
KMG Grinder Maker
testing:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hRM4KNy3FDM&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/hRM4KNy3FDM&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
HTML:
BossDog
Staff member
that for sure needs to be turned on...
I have got a clue how though and can't research it till later. If any admin or Supermod can figure it out, lets turn it on.
Les Voorhies
I have a test user named rover, I'll give him supermod and play around a little bit.
ooops, wrong thread :(
BossDog
Staff member
I have enabled youtube videos. Tech support on URLjet, the host ISP for this forum has been top notch so far...Especially Bob...
Here is an example link Youtube provides. It doesn't embed properly if you just put this into the square braces.
http://www.youtube.com/watch?v=HfkXQITJeic
You have to take everything past the = and then insert it between these two things: [youtube] insert here [/ youtube] (extra space between / and youtube to disable this example)
Or you can get it off the URL link.
http://www.youtube.com/user/tmickley1#play/all/uploads-all/2/HfkXQITJeic
it will look like this: "[youtube]HfkXQITJeic[/ youtube]" (I put an extra space just after the / symbol to disable this example)
[youtube]HfkXQITJeic[/youtube]
BossDog
Staff member
OK scratch all those instructions above.
Just paste the link from youtube into your message. That's it.
Bob at URLjet installed a plugin that takes care of everything else. We heart URLjet...
rfrink
KMG Grinder Maker
testing.......
[youtube]0OVk7mDfvO4[/youtube]
Finally got it...it helps if you read the instructions ...(forehead slap!)
K
Knife Crazied
Guest
My friend Rogue
[ame="http://www.youtube.com/watch?v=AbhK2ajuPnY"]YouTube - Environmental Moves[/ame]
Clydetz
Buck 110 Collector and Casper's best friend
I saw this guy on the beach juggling 3 knives. Funny... I thought he started out with a white shirt. :confused:
[youtube]ER3q16RqDz4[/youtube]​
