Dust collector
Guindesigns
I was wanting to either buy or make a dust collection system and hint tips or videos or blueprints any help will be great. I have a small area and need to be able to keep it clean.
"The Montana Bladesmith"
Here's one I built with a motor/blower out of a home funance....... uses 16x25x1 replaceable filters......
And a second that is a small/converted swamp cooler.....again with stacked/disposable furnace filters.....
Both are mounted to the false ceiling in my finish shop.....that way the air circulates, and all the heat doesn't get sucked out in winter..
opaul
Ed uses the same system I am currently using.
If you haven't seen the videos by Slavik Tely, you need to check them out ( thanks to Rick for putting me on that one.)
When I had my shop in the lean to, I didn't do anything but blow the dust out with my air compressor when it got real messy. Now that I have an enclosed small shop, I'm trying to be Mr. Tidy Shop :).
When I run the grinder, I either have my vacuum or filter station running (depending what I'm grinding.) I have started cleaning up and vacuuming after one task and before I start the next (well most of the time). I try to have the vacuum running or at least stop and vacuum up sanding dust and drilling chips as I'm working.
It takes discipline but I'm trying. Sorry for the long note :)
John Wilson
HF offers two units, a little one and a big one. I have had both, and the big one is a truly great unit. The little one is a piece of crap with a brush motor.
If you hook a dust collector to your grinder, be sure to add a water trap before the blower unit to keep from sucking sparks and embers into the bag.
Ditto to what John says! Personally I have a 5 gal bucket of soapy water hanging directly under each of my grinders. I also have a dust trap/shop vac connection to one......but that ONLY gets turned on with handle materials or non-sparking materials. I've seen several building burnt down over the years because folks were using a shop vac at the grinder..... and not thinking about what it would do! ;)
Wolbachia
New Member
Choosing the best dust collector for your home isn't easy. Jointers have different features that can make a significant difference in how well you work. Dust collector come in different price ranges and models. The best dusts collectors all have their pros and cons. Be sure to do your research and look for reviews from other users before purchasing. You can read on this site about best dust collector. In this way, you can make your choice easier. I think it's the best helper for you in this situation.
coachk
Active Member
I bought one of those small 1hp wall units a couple months ago to just work with my grinder and horizontal grinder . I got it mounted to the wall, but i don't want to use a bag, i want to run a direct line outside through a dryer vent...just gotta find time to cut the whole in the brick and find some tubing to fit the outlet side.
Edited to add: I will only use the dust collector for handle material grinding; i also use a water bucket for steel grinding
