"The Montana Bladesmith"
If so, then you own something that can be a great help with "hand" sanding!
This lupus stuff, has proven a challenge for many of the things I do. Hand sanding is a biggie....may hand hurt so bad I can hardly grip the sanding stick. So, I found something that has helped me tremendously. An oscillating tool! I found/purchased a universal dremel brand sanding pad (they all seem to have velcro on them), which I ground off to the rubber, and use a light coat of contact cement to "stick" the paper to the pad. It's tedious cutting out the sandpaper, but man is it ever speedy! At 600, I spent literally less then a 1/4 of the time I would otherwise spend hand sanding. Now, that being said, once done with the oscillating sander, I still finish by hand/with the sanding stick....but it's just a couple mins.
I happen to own a Makita battery operated oscillating tool, but any should work. Just thought I'd pass along the info.
There's a very short learning curve..... as in DO NOT press too hard, and train train your eye to see where the sandpaper is cutting. I like the pointed triangle shape of the sanding attachment.... it allow you to concentrate on a small spot/scratch, taking it out and blending the area. It's also easy to get into the plunge area with it.
