Disc grinders, what do you use them for?
Stang Bladeworks
I have had an AMK disc grinder for some time now and I have tried using it for a variety of things but I haven't found a great use for it yet. I have tried using it to:
set locks - I found the discs wear out fast and I can only set 1 or 2 before I need to change the disc. If I just use my grinder the 2x72 belt lasts a lot longer.
flattening stock - I thought I could just flatten one side and then use the surface grinder. In practice its no more accurate than just surface grinding both sides. Sometimes I need to swap back and forth to work out a slight bend but its no better on the disc grinder.
Sharpening - Again, it works just not as well as my grinder.
I have very limited shop space so having a tool I don't use isn't ideal. Is there another task I can use this for, am I overlooking something? I am hoping I can get some ideas. I kind of thought I would use it for a lot of things but it hasn't panned out yet. I make mostly framelocks and I do use cnc so using it for chamfers etc. isn't really necessary.
Thanks.
Smallshop
I do a lot of my work CNC also....I have a disc grinder that I have not wired up yet. I only want it for prepping scales for the cnc. Perhaps i will use it for touching up blade flats afer heat treating.
I've had it for 6 years lol...since I got ill i have had to move more work to the cnc...so it may sit another 6 years...lol.
I think a vfd might make it more useful? the speed is pretty crazy.
Taz575
They work great for octagon shaped Wa handles. They will square things up a bit more even than a belt sander and you can tilt the table and have a larger surface are than a 2x72 belt sander to cut the facets into the handle. I had 1 12" set up at 90 degrees and 1 set up at around 40 degrees to cut the facets on the octagon handle.
scott.livesey
Dealer - Purveyor
I use mine for final grinding and polishing of smaller blades, 5" or less, as i can grind entire blade all at once. also works well for shaping handles. i have variable speed 8" and i am finishing a low speed(350rpm) fixed speed.
8" seems to be the standard for metallurgy and lapidary. I have discs from 36 grit to P2500 grit. You have to use low speed, less than 500 rpm to get any life from discs finer than 150 grit.
BossDog
Staff member
When I want small flat areas cleaned up I use a disk. A belt grinder platen rounds the edges of parts where the belt puckers. I have ground a few blades on the disc but it is tedious. I now flat grind blades on a belt platen and then clean things up with the disc. I deburr folder parts on the disc and “polish” tang areas on a folder blades. Every blade I grind I use the disc to grind the flat part to my planned finish. A disc will give you a much crisper grind line. I get bolsters flat without edge gaps on a disk. I wouldn’t be with out one.
mike miller
I have a self made double grinder. One side has steel disc with 60 grit sandpaper on it. I use it to flatten and debark guard material. I hit all handle material on it to make sure it is flat. Second side has 1/8 inch rubber on it. I use it to further grind down guard material to 1000 grit and have flat ground on it. My tapered tangs are ground on belt grinder then I got to disc to further true and flatten tapers down. 60 grit side I use to profile blades also. The rubber side I spray with adhesive and use standard sandpaper sheets. Excess are cut and use for hand sanding.
BossDog
Staff member
This ties in. Blatant product placement.
EDITED TO ADD: The intro price stops at 20 sold, which will likely happen today and the regular price will be $195 going forward.
Daniel Macina
Just ordered one! Can’t beat the price and I always wished someone would make one that tilted horizontal and vertical.
coachk
Active Member
Yep, that was a good idea...I have 2 in my shop, 1 vertical and 1 horizontal...that would have been nice a while back!!haha
I make folders so I use mine quite a bit! I have a 90degree table on my horizontal and use it for cleaning up my spring and spring notch, and half-stop, making sure they're 90 degrees. I also true up bolsters and grind handle material to fit w bolsters, and chamfering my pins
The horizontal is what I flatten all my handle material and liners on...
I couldn't do without a disc grinder in my shop
Sent from my SM-G981V using Tapatalk
scherf68
Man, I want one but the shipping kills it for me right now. Will save up because that is a great design. I believe my spare motor will fit it. I can weld, will you be offering one like "you weld grinder?" That would help on shipping, I bet.
Damn, just and edit, my motor will not work.
