taylormadeknives
Anyone have any experience with heat treating this steel? I sent a couple out to Peter's Heat treat last time I used it because the time before I failed miserably at the heat treat. My foil wasn't rated at the temp I was soaking at and it basically burnt up.
I think they make a higher temp foil, but not sure. I buy my foil from Knifekits. It's rated for 2000 degrees. I found out that's it! Don't go over. Period.
Looking for a source of higher temp foul and any advice. I'm sure this can be heat treated at home with the right foil.
I'm using a heat treat furnace btw. I plan on doing my own cold treatment with dry ice and acetone. I've done many steels this way with good results.
Any sources for the foil would be great
