Conditioning Belts
Robert66
This hand sanding/polishing is killing me.
I sand to 120 then flog my things off with wet/dry.
Can anyone personally recommend a conditioning belt/s to fit a 4 x 36
I think Anthony Self just made a pist about using an electric palm sander.
Look for recent posts by Selfmade Knives. I think that’s a great solution for you.
The farther you can get your preliminary grinds down to the better off you’ll be. I will grind down to 600 at least, sometimes 1200. I also try my best to make sure that all of the previous grits scratches are removed.
After that I start hand sanding with 320, up to 1200. The whole hand sanding process takes between 10-15 minutes after that.
Conditioning belts will help with the end surface finish, but they won’t help much getting out the big grinding scratches.
