Cleaning Flats after heat treat
Greenhead
Active Member
Hey Guys,
Does anybody have advice on cleaning up flats after heat treat..specifically folder blades but fixed blades as well. It's always hard to get my W2 cleaned up after a clay heat treat. Thanks!
Jamie
BrandantR
Here's what I use.
It's a shop-made horizontal disk grinder that I built several years from an old foot massager that I picked up from a secondhand store. The disks have different grits of paper glued to them with good old Elmer's Rubber Cement to make replacement easy. They mount to the unit by slipping over a couple of metal dowels which hold them in place while the unit spins. I have a dimmer switch to control the speed and the direction of rotation is reversible. It works great for grinding flats and for final sharpening as well. It's one of the most useful tools in my shop.
