I have been heat treating my blades for some time now and the only real Problem is the brick with ceramic pegs to hold the blades and or foil pouches vertical in my Evenheat Kiln. Not too bad with unwrapped Damascus blades etc . But with foil wrapped SS blades, sometimes when I reach in and remove the foil pouch it catches the fragile pegs on the foil fold and breaks them off or tries to pull the entire brick out . Today I dropped the pouch ,caught a towel on fire and still managed to stomp the fire out and retrieve the pouch on the Aluminum plates . This just SUCKS and I am sick of it. I fold the pouches as flush as I can but they still sometimes hang up on the ceramic pegs. Can anyone tell me of a stable blade holder perhaps with brick blocks instead off little pegs or whatever . I could cut slots in some angle iron but not sure if the metal would soak up heat from the Evenheat Oven or whatever ???? I heard that the Paragon blade holder has brick base but steel pegs , but I need something that I can slide the foil pouches out without interference
