Bandsaw blades
Kev
Does anyone here know of a readily available and/or source for a wood cutting style blade for a portable bandsaw? I kinda have a one off project, that I really should use wood blades for. That said I could always go buy a wood cutting type bandsaw, but you know, if you don’t HAVE to...
thanks
billyO
My opinion is, if you can afford it, go and buy the dedicated blade with the proper TPI and kerf. If you don't forsee yourself using it frequently, then you can get a cheaper version and still have something that'll last for years, and the next time you have a one-off, you'll have the right tool.
I'll try to discourage you from using a metal blade to cut wood (except for K&G stabilized wood, maybe) because it can be frustrating, slow and the blade can wander.
Here's a good video explaining sawing wood:
Kev
I hear ya. Normally I’m all about new tools, this time it just seems a tad frivolous. That said, I think I’ll buy a new wood cutting bandsaw.
tkroenlein
I bought a 10" Rikon for wood and handle materials. My life is changed. I was able to find bimetal blades for metal that fit it and cut G10 as well.
KenH
Are you able to slow the 10" Rikon down enough for metal? How well does the blades last? What metal are you cutting?
I just got a 14" Rikon (found it used) and while it cuts wood really good, even on slow speed the blade is still about 1500 SFPM. Just for grins I tried a 14 tpi bi-metal blade to cut some .065" AEB-L and it dulled blade with just a few inches of cutting. Didn't get a whole profile cut out before it ruined the blade due to excessive speed.
tkroenlein
No metal. It's a 2300 sfpm 1 speeder. I have a horizontal that flips up for profiling. The bimetal just lets it live through G10. I suspect that life will be shortened compared to metal saw speeds, but it's so much nicer to be able to cut the sheets down square. I switch it back to the wood blades for wood and micarta.
tkroenlein
Not that I have ever seen, and I looked. But I bet you could get someone to make it. They're usually pretty reasonable.
Sean Jones
Before I got my Milwaukee Porta-Band I had a metal cutting band saw blade made for my Craftsman Wood saw. One blade cost me $45.00 and it didn't last nearly as long as I expected.
Kind of the opposite of what you are looking for, but I found one off band saw blades to be quite expensive.
Chris Railey
I did not think I had ever seen a wood cutting blade for a porta band. For my wood cutter I use the Lennox blades from Grizzly. I am impressed with them. Do not buy a 3 wheel Bandsaw no matter what. I had one and it was a blade breaking machine.
